Need help.
Ive been trying to get my car started for sometime now and i cant. its a 94 honda civic ex. I do not have spark or fuel. I live in temple terrace if anyone can stop by and try and figure it out i will throw you some cash.i need to get this thing back up and running.
check the ground on the thermostat housing make sure its secure as well as all other grounds.
Married to EkCoupegirl
Current Cars
05 ZX6R FOR SALE! Help me pay for school
PM me for info.
95 Civic EX 4dr- D.D.
99 GMC Sierra 5.3l ext. cab. Under construction
05 Kawasaki Ninja ZX636R Plasma Blue
Current Cars
PM me for info.95 Civic EX 4dr- D.D.
bump. Got the car running now its doing it again!Last time it was a fuse that was missing.Car randomly stopped working one day and would also turn on randomly.Now i havent been able to get the fuel pump to prime in a few days. Ive checked all fuses with a multimeter everything checks out good. Im not getting any power to the fuel pump. I bench tested the main relay it tested good. Cleaned thermostat ground. fuel pump ground is good. My only guess is the ECU... Dont have the money just to throw in for a new ecu. Anyone have any suggestions on where to go next.
fuel relay bro. it may be corroded internally. u can try hold the sides together while turning the key to the on position and see if the pump primes. if not try swapping out the whole unit. hope it helps.
Have you checked hood fuse 31 and dash fuse 24? Do this FIRST!
Does the check engine light come on and go off after a few seconds, proving ECU is good?
Does the main relay click, proving the ignition switch is good?
Jdm b18c R LSD CRX si
TR "Old Skool EF" Member #96
JoKie TuNinG
RANGCRX BUILT TYPE R
StricKlyMT
727-510-6301
JoKie TuNinG
StricKlyMT
727-510-6301
Ive checked both fuses with my mulitmeter both tested good and both were getting power at the fuse.
Check engine light stays on after the one position.( i do not think the ecu could be dead if the car starts up randomly sometimes)
Main relay only clicks once. I benched tested the main relay checked out good aswell as the ignition switch to manufacture specs.
Reset the ECU see if code comes back
What is the code?
If code 0...you definitely have ECU problem
What is the code?
JoKie TuNinG
StricKlyMT
727-510-6301
JoKie TuNinG
StricKlyMT
727-510-6301
