Car wont start..
Old Nov 13, 2002 | 02:31 PM
civicracer901's Avatar
B16ACRX
Default Car wont start..
Well I think its my starter. I use to be able to turn the key and it starts up right away. A couple of days ago I started the car up and it wouldnt start up it would hessitate to start. I replaced the battery with a brand new one. It needed on anyways. It still didnt start. Then i jumped the car and it started up fine. I shut the car down 3 times just to see if it would start on its own. It did fine for a the whole day. Well I get up one morning to start the car up. It turn the key and i her this loud click. Nothing is comming on I have no headlights comming on or nothing. No power etc.. nothing at all. Does anyone know any things that could be wrong or ask me more questons of why its not starting aim civicracer901. please i need help with this right away. Also I need to know will the starter be the cause for not having power. The battery is brand new and tested fine.
WTB:A clean 90-91 civic hatchback. Red or black or white in color. Good exterior. Looking to spend around $2,000.
Old Nov 13, 2002 | 02:50 PM
crix's Avatar
:mugen member:
Make sure batt. cables are tight &
ground cables are tight
also check the cable on starter(for tightness)
Does batt. light come on when car is running(the light on cluster/dash)
if so could be alternator
Old Nov 13, 2002 | 02:55 PM
B16ACRX
alternator is in good shape ,all fuses battery cable and under hood fuses are all ok and checked. I pulled the starter out and checked it and it checked out good according to the helms mannual. The ground cable from the battery and starter cable i checked and they all have good conectivity. I was thinking the ecu because of the way its sitting on my floor board. exposed . brb iam checking the pins and crap and waht not. thanks. I still need some more help.
Old Nov 13, 2002 | 03:01 PM
crix's Avatar
:mugen member:
Are the cables corroded?
hard to tell unless seen!
Old Nov 13, 2002 | 03:04 PM
B16ACRX
well as much as a retard iam it was a lose neg. battery cable i bumped my head on my hatch lid trunk and it moved around a little bit and i heard my rader dect. and fan come on cause its a 24/7 fan . thanks for the help people
Old Nov 13, 2002 | 05:03 PM
crix's Avatar
:mugen member:
no problem
