Skunk2 tuner cams vs Skunk2 Pro 1s
Old Aug 23, 2011 | 08:50 PM
icegsr's Avatar
Default Skunk2 tuner cams vs Skunk2 Pro 1s
Anyone has experimented with the Pros please post your experience. I've seen some guys who had there vtec set higher that usual with the Pro 1s. And yes I did a search but didn't find much info. Thx for the help.
Old Aug 23, 2011 | 09:19 PM
97EJ-6's Avatar
Kiss Mi Ras!!!!!!
It all depends on compression
JumpManPm me for any needs for a Honda/Acura/Evo. From tune ups to motor builds TR "Old Skool DA" Member #91Still Jokie!!!!!!!!!
Old Aug 23, 2011 | 09:22 PM
Paulino's Avatar
Not harsh, just truthful
What about on a 1.8 liter 12:4:1 ls/vtec?
Old Aug 23, 2011 | 09:23 PM
97EJ-6's Avatar
Kiss Mi Ras!!!!!!
Pro 2s if you go with skunk2
Old Aug 23, 2011 | 09:30 PM
icegsr's Avatar
Got CTR pistons.
Old Aug 23, 2011 | 09:54 PM
97EJ-6's Avatar
Kiss Mi Ras!!!!!!
I have pretty much the same setup but with crower stage 2s makes over 200 whp with supporting mods and has good low end torque but skunk 2 stage 3s or pro 1-2s will do good work with that setup also just will have a higher powerband...
Old Aug 24, 2011 | 10:12 AM
icegsr's Avatar
Thanks for the info.
Old Aug 24, 2011 | 10:30 AM
EJ95's Avatar
I have experience with the Pro 1s and they sound awesome and give you good top end power (I made 180whp on a B16).... mid range sucked though. But mind you, it was on a B16 with 11:1 compression, so I did not have ls torque or as high of a compression as you do... IMO you should have a small shot to go along with your motor build to give you just that much more of a punch at low end - mid range. Like a 25-50 wet shot... Just my 2 cents.
Proven Power FTMFW! 813-988-3966 (DYNO)
Old Aug 25, 2011 | 04:29 AM
88_Hatchy's Avatar
I'm cooler than you
Your compression will be above 13:1 with those pistons.
Honda-Tech > TampaRacing
TR "Old Skool EF" Member #666
Old Aug 25, 2011 | 09:25 AM
KJ's Avatar
KJ
bored at work
You really need to pay close attention to the piston to valve, valve to valve, and retainer to guide seal clearance when running any of the pro series cams. If you don't have the means to measure those stick with the tuner stage 2's they are much more of a drop in cam.
