Hondata
Hondata
I know this sounds stupid but will a Hondata ODB0 ECU control the DPI FI system in the 88-91 DX/LX civics or is it only compatible with MPI?
Also, in a DPI or MPI FI how important is the placement of the TB and MAP in relation to the actual injectors. And how close does the O2 sensor need to be to the engine. I am wondering the possiblities of retrofiting a Honda FI/ECU system onto another engine.
Guest
Posts: n/a
|\|0p3, 0|\|ly c0mp471bl3 \^/17h MP1. DP1 7h|20\^/ 17 1|\| 7h3 fuck1|\|g g4|2b4g3 - c4|2b'd fu3l 1|\|j3c710|\| |\|3v3|2 \^/0|2k3d \^/3ll 0|\| 4|\|y c4|2. |\|071c3 4ll p3|2f0|2m4|\|c3 3|\|g1|\|35 1|\| 7h3 h0|\|d4 f4m1ly d0|\|'7 u53 17...
ju57 |23m3mb3|2, y0u d0|\|'7 h4v3 70 |231|\|v3|\|7 7h3 \^/h33l 70 b3 0|21g1|\|4l
Hondata and factory honda fuel system (up to 150HP for app I was considering) is about $500 for the ECU and factory honda parts to retrofit. AEM is $1200 + all the aftermarket fuel system stuff and the Hondata will give me all the tuning I need, much better than the carb that is currently in use.
Originally posted by "foesicks"
Hondata deals with obd0 or just the jdm obd0 ecus?
They have tons of info and you will find the answer to your question.
Yeah I took a look just after I posted, seems to be just jdm pre obd ecus. thanks anyways.
What is the difference in the ECU's that the us ones couldn't be used?
Guest
Posts: n/a
1f y0u 4|23 V73C, H0|\|d474 15 7h3 \^/4y 70 g0 88-2000/2001 (1|\|73g|24). 175 50 345y, y0u \^/0uld|\|7 3v3|\| k|\|0\^/ y0u h4v3 1|\|j3c70|25 0v3|2 d0ubl3 (0|2 3v3|\| 7|21pl3) 7h3 51z3 0f 570ck. |\|0 V73C 0|\| y0u|2 88-91? Zdy|\|3 15 4 v3|2y c0mp4|24bl3 5y573m, 47 4b0u7 7h3 54m3 c057.
