Code 43 plz go away help me!
Old Jul 15, 2011 | 11:12 PM
2qk4u's Avatar
Default Code 43 plz go away help me!
has anyone seen code 43 its a fun one. i cant get rid of it. changed every god damn thing possible and my car still gets code 43 randomly and bogs out like mad. my last 2 cars both had it and the only thing the same that i swapped over was the intake manifold and sensors but code 43 doesnt have anything to do with that i dont think.
when i research it it says main prob is o2 sensor but mine is disabled in the ecu.
it then says change. pump/filter/injectors. done all that to. changed fpr to.
im running 44 psi at my fpr. when i get the code it feels like im riding a bull the car bucks so hard.
usually takes about 45-60 mins of constant driving and then BAM CODE 43 UP MY ASS AND MY CAR BOGS. yet i can take 20 pizza deliverys in one day and not have one problem with it. its fucking confusing
Old Jul 15, 2011 | 11:14 PM
2qk4u's Avatar
sometimes simply turning the car off and on makes it go away but then comes back later sometimes
which makes diagnosing it really hard
Old Jul 16, 2011 | 06:05 AM
NeKe1point0's Avatar
Do u have a fuel pressure gauge or wideband to confirm you have steady 44psi when the bucking happens ?
Proven Power LLC
4505 N. 56th street
Tampa, FL 33610
813-988-DYNO(3966)
www.ProvenPowerTampa.com
Old Jul 16, 2011 | 07:37 AM
2qk4u's Avatar
definetly not steady fuel pressure when the bucking comes on. the FPR gauge goes fucking crazy up and down
Old Jul 16, 2011 | 08:38 AM
BoostedRacerDad's Avatar
Pops
Jdm b18c R LSD CRX si
TR "Old Skool EF" Member #96
JoKie TuNinG
RANGCRX BUILT TYPE R
StricKlyMT
727-510-6301
Old Jul 16, 2011 | 09:11 AM
integra's Avatar
90% grind 10% sleep
+1 to Pops....
OP,Just because its disabled in the ecu, doesnt mean a loose wire or something along those lines wont cause the problem.
Honda Valve Adjustments 50$
I TUNE KPRO AND S300
I DO NOT WORK FOR FREE
Originally Posted by THE_ONE
Old Jul 16, 2011 | 09:26 AM
2qk4u's Avatar
the fucked up thing is its intermitant. i can drive for weeks and weeks and never have the problem.
i mostly get it on longs trips to and from tampa/orlando
Old Jul 16, 2011 | 09:27 AM
2qk4u's Avatar
neil sutton did my wiring so im pretty sure thats not the issue. unless something came loose somehow
Old Jul 16, 2011 | 09:28 AM
2qk4u's Avatar
how can i test an o2 sensor thats disabled in the ecu i dont understand?
if its disabled a loose 02 wire dont matter the ecu dont even read it.
Old Jul 17, 2011 | 06:43 AM
Pops
Orealllyyyy. I know you aren't running Hondata but check this out.Hondata • View topic - Throwing O2 sensor CEL after tuning on Hondata
Pm anytime. I'm assuming we got the major problems under control?
JoKie TuNinG
StricKlyMT
727-510-6301
