Quick guestimation....
Guest
Posts: n/a
Would those of you who know my setup.... What whp do you feel that my car should have with my setup...?
Ive been guessing anywhere from 180 to 250. Just to keep it at a wide spectrum of error. To not look like I'm talking out of my ass about it.
I would actually say somewhere in between the two numbers.
Im really hoping for 200tq but that may be stretching it.
The boost will be set ~10-12psi for normal apps, and depending on A/F ratio. 14-17 strip. I will dyno the car slowly adding boost to test the A/F and see where she likes to be set. Anyhow... Im gonna stop rambling.
i dont know alot about sohc turbo, cept that i never knew anyone who went faster than a low 14 on a built single cam turbo
im sure there are some around though.
maybe.
LS turbo at 10psi will do about 250hp
ls/vtec at 10 psi will do about 290
thats according to a honda tuning mag i have
so i think u wont be anywhere near 250
more like 200 or less
and u wont have shit for torque, which is the issue with the singlecam
the horsepower will be there, but u cant pull that much torque froma single cam
some guy mike or someshit with a black 4door coupe had a singlecam turbo that he boosted to hell and had a 50 or 75 shot he said and only ran like high 12's
which is fast but he did waste alot of money to get a high 12
maybe.
Guest
Posts: n/a
at low boost, 7psi, I had 135.5tq, and 156.9whp.
Im assuming aprx 207@10psi as things sit. Non tuned. After hondata I am certain we can fatten up that hp curve. The cam will help with torque. alot. Cam timing with the right profile can make a world of difference.
Who cares if he's a doubter.
[edit] Might I refer you to our sticky post regarding bashing in the tech forum? read it now.
Walter
a.k.a. Speed_daemon1[/edit]
Walter
I own Cronic Burn, Chron, @whatever car he's got...
