my car. always stays cold need help.
Have a single cam with y8 head if it matters, when first got it the car would never warm up at all, after drivin on the highway for a little it warmed up a tad bit but no where near normal temp.
Then noticed the car has no thermostat and the air temp sensor was bad replaced both because it was throwing a code for the air temp no code now but still will not get warm. At all.
Could it be the temp sensor even tho its not throwing a code? Any suggestions would be apprecite it
the temp sensor for the guage wont throw a code.
Honda Valve Adjustments 50$
I TUNE KPRO AND S300
I DO NOT WORK FOR FREE
727-510-6301
so it could be just the temp sensor?im thinking that but what got me before is that the gauge still moved when there wasa no thermo just a tad bit after driving for a while. il see if i can find one and change it to see, one thing after another with these hondas
I actually disconnected the temp sensor from the harness and it does throw a code, so im guessing its working. put a new thermostat still wont get warm, i checked the cluster and everything is connected, so i am clueless
temp sensor for the gauge is a single wire sensor..The 2 wire temp sensor will throw a code.
727-510-6301
Just what Mike said...The sensor is a one wire for the guage cluster.
727-510-6301
well im officially a dumbass
the snesor with the 1 wire coming from it is CUT!.
my car is wire tucked and nor do i know where the hell the wire is supposed to connect to, so i have a few bucks for whoever wants to take this on $$$$$$$$
the snesor with the 1 wire coming from it is CUT!.my car is wire tucked and nor do i know where the hell the wire is supposed to connect to, so i have a few bucks for whoever wants to take this on $$$$$$$$
location?
727-510-6301
