battery keeps dying,
I just rebuilt a 95 accord 2.2 non-vtec. when the car sits for a day or so, the battery totally drains. brand new battery alternator and distributor. we check each connection like the book says, but this is starting to piss me off. could the starter drain it.
stereo equip can drain but usually not that fast
bad cell in the battery maybe? bad connecting wire? have the battery tested if you haven't already. have the alt tested if you haven't already. i know they are new but nothing is ever perfect.
i take it since the battery is new you used a higher powered battery for your rebuild (honestly, i don't know if you needed to or not but just a thought)
those are just my ideas.
if you can only race me in a straight line then whats the point
...91 SMF SCCA
...91 SMF SCCAhttp://www.flickr.com/photos/8341770@N07/5601083432/http://www.flickr.com/photos/8341770@N07/5601083432/ by http://www.flickr.com/people/8341770@N07/, on Flickr
– the late Tom Thrash SCCA Solo E Production
Buy a cheap multi-meter. Hook it up to your battery........then start pulling fuses one at a time. As soon as you see the voltage jump up a little. Then what ever is routed to that fuse is a starting point for you to start checking. If nothing happens doing that. your problem is somewhere before it gets to the fuse box. You may have another fuse box under the hood also. If so, repeat that process there as well.
