lsvtec
uh huh it can, im thinking there might be something you need though, not sure, but it can be done....if there is a will there is a way....
Quote : I'm Slow:
Less hours = less $$. Less repetitive 'ish every day = PRICELESS!
Quote : I'm Slow:
Originally posted by "99B16Si"
the machining wont cost more than 50 bucks. all that has to be done to the head is wide holes for the movement of the dowel pins and tap the vtec supply line so it can be plugged.
unfortunately the right size drill bit will cost you $20
you can get a tap and plug pretty cheap, just don't forget to use teflon tape on the plug.
I've done it a couple of times. Works great. Actually my motor was a 1g b16a head on an ls block, ran strong for over 2 years.
Gracie Barra Clearwater
Yeah the block needs to be 90+ b18a/b block.
