Stripped coil screw
Old Oct 14, 2002 | 09:15 AM
Rhaco's Avatar
Default Stripped coil screw
The positive coil screw in my distributor is beginning to strip. i need to get it out so i can attach a wire to the positive terminal. any ideas or suggestions?
Old Oct 14, 2002 | 09:54 AM
Levi's Avatar
use something to cut a new slot in the head of the screw, try a dremel tool with a small cutoff wheel, cut a new slot and you should be able to get the screw out.
custom parts is our perfection.
Old Oct 14, 2002 | 07:37 PM
Bill's Avatar
Livin' in Seattle
Options:
- Vise grips
- Dremel a line
- Drill the head
