Car wont go into gear when running
Old Apr 30, 2011 | 12:51 PM
Aban88's Avatar
Default Car wont go into gear when running
Whats up TR, need some advice and have been getting mixed answers and just wanna find out what i need to do to fix the problem. When my car is off i can shift into all gears perfectly. When the car is on i have to pump the clutch ALOT then FORCE it into first gear. Once the car is in gear i can shift with difficulty to the other gears. Alot of the times i will hear grinds when i shift and the clutch is all the way engaged when i do. Also the pedal is low too. I've heard pressure plate issues, get a new clutch kit, or look for leaks in your master cylinder. No leaks at all! PLEASE HELP, this is my daily and cant be stranded.
Thank You
Old Apr 30, 2011 | 01:16 PM
Hybrid_Ej1's Avatar
5th ej1 one in the making
check transmission fluid sometimes when its over filled it will do that and make sure its not too low either
EJ Crew Member #2
Old Apr 30, 2011 | 02:48 PM
Aban88's Avatar
ya i saw some other prelude owners say the same thing. I'm gonna do that tomorrow and see what happens.
Old May 1, 2011 | 12:49 PM
The Fast Acura's Avatar
Has teh VTEK!
hit up matt at stricklymt check my sig for the number
K*Squad
DC-Crew #37
STRICKLY MT
Old May 1, 2011 | 01:03 PM
Josh.'s Avatar
The Integra Guru!
Check Fluid, If not fluid. Change clutch kit. Pressure plate, Pilot Bearing, Throw out bearing, Fly wheel resurfaced (Or new one depending on condition) and Clutch disc, Along with Syncromesh or Honda Fluid.
But when that happens it's almost 100% the Throw out bearing, Or pressure plate.
Old May 1, 2011 | 06:52 PM
MikeyL513's Avatar
BOOSTIN
Bleed your clutch.
cheeseburger407
Projects and Builds
Jul 2, 2011 05:54 PM
ccadman
Nissan/Infiniti Tech
17
Oct 19, 2005 02:54 AM
Viper4ug
Aug 10, 2004 04:33 PM
