Car will not start if you turn the key
Old Apr 25, 2011 | 05:32 AM
Secondz's Avatar
Built Not Bought
Default Car will not start if you turn the key
So if you turn the key all the way my car still wont start... it starts if you pop start it or jump the starter so i dont think my starter is bad or anything.
Any help is appreciated.
Old Apr 25, 2011 | 10:24 AM
SolScifen's Avatar
your battery's probably dead if you can push start and jump the starter. does any of your lights on the dash come on when you have the key in the position right before on?
Old Apr 25, 2011 | 10:45 AM
Secondz's Avatar
Built Not Bought
Battery seems fine, all the lights go off tho when the key is all the way to the start position... Radio comes on, headlights, interior light.. everything....
Old Apr 25, 2011 | 11:31 AM
MikeyL513's Avatar
BOOSTIN
jump the clutch switch and see if it starts
Old Apr 25, 2011 | 12:06 PM
Secondz's Avatar
Built Not Bought
explain how?
Old Apr 25, 2011 | 12:46 PM
MikeyL513's Avatar
BOOSTIN
if you look under the dash at the switch its on the back of the clutch pedal. Never done it myself but im pretty sure its 1 wire going to the switch and 1 wire coming from the switch. Conntecting the wires instead of them going to the switch jumps it. If your car starts like that, that means your clutch interlock switch is bad.
Old Apr 25, 2011 | 02:33 PM
Secondz's Avatar
Built Not Bought
Jumped it and still doesnt start.
Old Apr 25, 2011 | 03:53 PM
SolScifen's Avatar
what does it do when you try and start it? does it just make a clicking noise? sound like its cranking and no spark?
Old Apr 25, 2011 | 05:55 PM
Secondz's Avatar
Built Not Bought
Doesnt do anything.. lol, starter doesnt make a noise, and no... doesnt crank.
But the car does start and run if you push start it or jump the starter directly to power
Old Apr 25, 2011 | 06:12 PM
Gotrice?'s Avatar
ignition switch
try and turn the key harder than usual you might need to change it
Midori Teg in the making..
