QUESTION d16 head for boost..
Old Apr 23, 2011 | 11:16 PM
b15spec's Avatar
aint no reg. spec-v
Default QUESTION d16 head for boost..
If there would be one thing in the valvetrain to change being aftermarket for a turbo build which one would apply more over the other. The valve springs and ret. or the valves itself?!
Im already going with a decent cam but if i got to the point if i had a money grind which one would be better to change to withstand the boost more? any hel p is greatly appreciated.
https://www.tamparacing.com/forums/signaturepics/sigpic51275_1.gif
Old Apr 24, 2011 | 06:21 PM
b15spec's Avatar
aint no reg. spec-v
no one with prior experience????
Old Apr 24, 2011 | 07:14 PM
mtber's Avatar
What is your power goal on what kind of fuel?
What turbo/manifold/engine setup do you have planned?
Old Apr 24, 2011 | 08:37 PM
b15spec's Avatar
aint no reg. spec-v
Id be happy with 300, not using anything but 93. Eagle rods/vitara pistions, 57,63ar turbo. Around 16-18psi w/ good ole 450, 550 max but im not sure i will max out the dsm's. And log style manifold.
Heard numerous people with over 300 with stock head so was just wonderin.
Old Apr 25, 2011 | 04:26 AM
mtber's Avatar
Stock head would be fine for that application.
Old Apr 25, 2011 | 07:19 AM
b15spec's Avatar
aint no reg. spec-v
Iv heard that it would be as well, but my MAIN questions here is if i was to do anything to the valvetrain any single thing, like the valves, or valve sprigns, which would i get the better advantage from power and reliability wise.
Old Apr 25, 2011 | 11:42 AM
mtber's Avatar
You wouldn't gain power by changing the valves or valvetrain, you would only gain power by going to a different cam.
Old Apr 25, 2011 | 03:25 PM
b15spec's Avatar
aint no reg. spec-v
Wouldnt you need an upgraded valvetrain to rev higher or would it not matter because you would have already reached a peak power band by the stock z6 rev limiter? and what cam would make a good pwoer difference on a STOCK valvetrain.
...Was looking at the bisimoto
Old Apr 25, 2011 | 03:27 PM
Ls_[eg]hatch's Avatar
mowchowbrowncow
id do springs & retainers just to be safe...thats just me tho.
Old Apr 25, 2011 | 03:38 PM
mtber's Avatar
Correct
I wouldn't recommend any aftermarket cam on the stock valvetrain.
