$420 cash+ a lick on the nuts to whoever can answer me this
Originally posted by "Gary"
on the same note.. how do you remove the door panels? are they screwed in somewhere? or glued or something?
one screw by the door lock...
one screw where the pwr window are is ( the little handgrip on the inside)
one small -plastic screw and grommet up front by the dashboard about 4 inches form the top
then pull off the speaker grille (i find it easier)
then work your fingers under the bottom edge by the back of the door, and give a decently sharp tug, it should pop.. then just a few more of those around the dooor
then lift it up, and slide it bacwards a bit, finagle it aorund
man, i know exactly what your talking about 93ex. my driver side window is anoying the hell out of me. it also keeps coming off the track. at first i thought that my tint might have been causing the window to mess up, so i took it off then, pop goes my window. thanx to this tread, i can finally get my window fixed.
my drivers window does it, esp on the hot days.
thanks to crime i am on my 3rd drivers window. i just help it down when i can, it goes up jst fine.
Eat a live toad every morning, and that will be the worst thing to happen every day.
