speedometer help please please please k24/6sp rsx kpro
Old Apr 15, 2011 | 05:34 PM
lopezchris21's Avatar
Default speedometer help please please please k24/6sp rsx kpro
ok guys. I got a k24 with 06si 6sp tran in a 02 rsx-s with kpro. I recently got it and the guy who i picked it up from says that there is a way to hook up the vss with the kpro and not needing a frequency converter that the kpro can swap it over. Now he says that i need to extend the vss plug and plug it in the tranny and enable the countershaft option in kpro. In addition to put in a pin is e25 which is the vss out and connect that to c15 which is the vss reading at the cluster.
Now i enabled the countershaft and extended the plug and disabled the constant vss to read the actual reading and my vtec stopped popping so i know that its not reading speed so the wires to the vss may be mixed or not in right order.
If anyone can verify this and help me it would be much appreciated.
If anyone can text or call me and help me do this and get it to work, i will be more then happy to paypal a couple bucks in appreciation.
Phone number is 954-328-6166. thank you for your time.
TR 5th Gen Civic CREW Member # 04
Old Apr 16, 2011 | 09:46 AM
Wheres all our wire gurus???
Old Apr 16, 2011 | 12:16 PM
integra's Avatar
90% grind 10% sleep
you need a converter,or you need 05-06 Kpro...
Honda Valve Adjustments 50$
I TUNE KPRO AND S300
I DO NOT WORK FOR FREE
Originally Posted by THE_ONE
Old Apr 16, 2011 | 12:24 PM
BoostedRacerDad's Avatar
Pops
^I knew you would know.
Jdm b18c R LSD CRX si
TR "Old Skool EF" Member #96
JoKie TuNinG
RANGCRX BUILT TYPE R
StricKlyMT
727-510-6301
Old Apr 16, 2011 | 04:14 PM
I have the newest kpro that has the countershaft option and the thing with the o5 is the conversion harness and all it has is a pin already installed at e25. I've seen people put a pin in and wire it to the dash and wire the vss a certain way and get it to work which is what I'm asking if anyone know.
I also need to know from the tran vss plug to a 02type s plug if the wires stay or if the wires need to be switched up.
Old Apr 17, 2011 | 04:27 PM
No1 else?
WakaFlakaFlame
For Sale/WTB Honda & Acura
18
Apr 9, 2011 04:42 AM
Berto
21
Oct 10, 2010 11:56 AM
TypeRdc5rsx
13
Jul 2, 2010 07:43 AM
97HondaCivicEX
Apr 1, 2010 07:42 PM
