weirddd check engine light, can anyone figure this out?!?
sooo i got a swapped DA with an obd0 b16. instead of the normal pr3 ecu thats supposed to be with it, there is an ecu for an automatic, still gets the car going and can pop vtec. when i start the car, there isnt a check engline light, not until i drive for a good 5-10 min until the car warms up. THEN, the check engline turns on...it doesnt seem to mess with anything performance wise besides the fact that it starts to idle a tiny bit weird when in neutral. what i mean by that is that it would be at the normal 900ish rpm and then go down to like 300-400 rpm as if the car is about to die but it doesnt and usually corrects itself. the other weird thing that happens when the light turns on is that if im going a constant speed with my foot not moving on the pedal at all, the car seems to "cut off" and sort of slow down and then catch itself, as if its hesitating kind of...anyone have any idea why this lights going on!?!
i got a chipped PR3 for 80$
Honda Valve Adjustments 50$
I TUNE KPRO AND S300
I DO NOT WORK FOR FREE
727-510-6301
gotvtec20
Oct 28, 2002 05:50 AM
