Cooling fan problem...please help!
Old Mar 13, 2011 | 10:40 PM
xXJDMGIRLXx's Avatar
Default Cooling fan problem...please help!
I have a 1990 Crx and my radiator fan won't come on..if I give it direct power it will.
Does anyone have any ideas why?
Please help me out.
Old Mar 14, 2011 | 03:05 AM
BoostedRacerDad's Avatar
Pops
Start with checking 15A fuse in position 15 replace if blown
I bet your relay is good so move to Fan switch. locate it and remove plug and run a piece of wire between the two connectors. with key in On fan should run. Replace thermal switch if fan runs.
Jdm b18c R LSD CRX si
TR "Old Skool EF" Member #96
JoKie TuNinG
RANGCRX BUILT TYPE R
StricKlyMT
727-510-6301
Old Mar 14, 2011 | 03:31 AM
VTECracker's Avatar
MDJ_KUF
^its your thermal switch. wire passed until you can replace it
Old Mar 14, 2011 | 03:36 AM
Pops
Its located on back of block if you are not swapped. Should look like this.
Honda CRX Coolant Temperature Sensor | Free Shipping | 1988 - 1991, Standard, Beck Arnley
JoKie TuNinG
StricKlyMT
727-510-6301
Old Mar 14, 2011 | 07:12 AM
ok thanks guys ill try that.
The car has been swaped any ideas where to look?
Old Mar 14, 2011 | 07:42 AM
Pops
B swapped is on thermostat housing
JoKie TuNinG
StricKlyMT
727-510-6301
Vicious
May 24, 2006 12:24 PM
DrftDmn
Nissan/Infiniti Tech
23
Sep 6, 2005 06:25 AM
sl2racer
Apr 24, 2005 07:07 PM
TheShow50h
Nov 16, 2004 07:44 AM
Slash
14
Jan 21, 2004 08:17 PM
