gsr crank
does anyone know how to tell a gsr crank from any other? is there a web site with journal specs so i could mic it? i am buying a gsr crank tommorow any need to find out asap.
thanks steve
thanks steve
Hey Steve this is Jerome I am assuming they finally got the crank cleared well if you want spec sheets on cranks the only thing I can think of is doing a search and check. But I wouldn't cheat you like that. if you take the codes of the bottom of the crank and take that to the dealership you should be able to find something that would help you but collin will know when he sees it exactly what it is.
I am an honest guy I wouldn't screw over a fellow racer like that.
