what has more hp the gsr with stage 2 cams or a b18a1 with a gsr head and stage 2 cam
Old Feb 25, 2011 | 05:18 PM
jdmtegra's Avatar
Default what has more hp the gsr with stage 2 cams or a b18a1 with a gsr head and stage 2 cam
ok i had a stock gsr b18c1 with stage 2 cams and now i am looking into building a ls vtec b18a1 with my gsr head and stage 2 cams wich motor will be faster the gsr or the ls vtec
will i be let down when the ls gets into my teg or will it be a change for the better
the ls block is a used block with used pistons and rods from the junk yard they look all fine though nothing is messed up the pistons say pr4 on them i dont know if thats good or bad?
Old Feb 26, 2011 | 08:38 AM
88_Hatchy's Avatar
I'm cooler than you
Im gonna go with the GSR, because when you hit VTEC with those LS pistons its going to bend every valve.
Honda-Tech > TampaRacing
TR "Old Skool EF" Member #666
Old Feb 26, 2011 | 10:02 PM
jdmtegra's Avatar
how will the valves get bent ? is it because it has stage 2 cams i have seen ls vtec gsr head with b18a1 bottom but with stock cams and even when the vtec hit nothing went wrong
Old Feb 27, 2011 | 07:15 AM
88_Hatchy's Avatar
I'm cooler than you
Originally Posted by jdmtegra
it has stage 2 cams
This.
Old Feb 27, 2011 | 07:13 PM
eightwun3zfynest's Avatar
sleeper
dont do lsvtec. my boy just did it and blew it within 1 hour! not reliable alot of people get lucky building it!!
Old Feb 27, 2011 | 07:26 PM
88_Hatchy's Avatar
I'm cooler than you
They are perfectly reliable if built correctly. A lot of people have no business building engines.
Old Mar 4, 2011 | 03:58 PM
84mm SC61's Avatar
very true.............................................
Old Mar 4, 2011 | 04:27 PM
LShatch98's Avatar
i love making you mad <3
this.
if you build any motor half ass its gonna blow. he probably used all used parts/cheap ass parts and tried to rev it to the moon. building RIGHT its 100% realiable. but when you build it useing used or cheap parts what do you expect??
Proven Power for all your go fast needs
Old Mar 5, 2011 | 01:35 AM
Ls_[eg]hatch's Avatar
mowchowbrowncow
this!
haha ppl who say ls/v's aren't reliable are usually wrong.
Id do a GSR tho...my reasons being you already have the motor, GSR's have oil squirters,gsr are already made to spin 8k+, & yer GSR compression will be higher than a stock ls/v "witch you will like to have with bigger cams"
Only plus about Ls/v's are the tad bit of stroke you get out of them..." & its not even noticeable."
Im running a ls/v setup & put about 1000 miles a week on it for the past 3 months & have never had any major problems
Old Mar 7, 2011 | 07:53 PM
MikeyL513's Avatar
BOOSTIN
^Thank you, i hate when people do ls/v and all the sudden think the bottom end can rev to 9.5k..
