Cam pulley bolt.
Old Sep 25, 2002 | 07:10 AM
Bill's Avatar
Livin' in Seattle
Default Re: Cam pulley bolt.
Originally posted by "CronicBurn"
I broke mine off in my head while adjusting cam timing. (stock cam gear)
Im wondering if moving the cam gear bolt (tightening) is the recomended way to do this... or is there a safer way to adjust cam timing w/o using the crank pulley....
Adjusting cam timing by tightening the cam gear bolt??
What the hell are you talking about?
If you don't have an adjustable cam gear, the only other way to adjust the cam timing would be to move the pulley a tooth or so.
Old Sep 25, 2002 | 08:44 AM
KJ's Avatar
KJ
bored at work
When I adjust cam gears I loosen the three to six adjustment bolts (depending on brand) and then spin the inner portion of the gear to where I want it by turning the pulley bolt one way or the other. How did you manage to break the bolt off?
Old Sep 25, 2002 | 08:45 AM
KJ's Avatar
KJ
bored at work
Old Sep 25, 2002 | 10:24 AM
98VR6's Avatar
Default CAM GEAR
DON'T PUT THE BOLT SO TIGHT NEXT TIME. IF YOU HAVE THE TOLL TO ADJUST COIL OVERS IT WORKS GREAT IT FITS PERFECT OVER THE CAM GEAR. :monkspank:
IF YOU CAN'T RACE IT OR TAKE IT TO BED IT'S NOT WORTH HAVING!!!!!!!!!!!!
Old Sep 25, 2002 | 10:33 AM
Sneakin Deacon's Avatar
PSSHHH x2
well option 1...back the bolt out and find urself a new one...option 2 (not advised) tap the belt off the gear evenly and softly as to not damage it, then using a screwdriver move the gear (mark a tooth on the belt and cam gear to see how much u adjusted...then when u have it where u want use the screwdriver and turn the cam till it moves back on because its to hard to just put on...but i wouldnt advise this as i said earlier, ive done it on occaision but it was a "have to do it now" situation..
btw..you can adjust the timing with your dist. too...
El Pendejo Loco
2002 Suzuki Hayabusa
1507 "dry" block
Brocks megaphone
Spencercycle 10" swingarm
MPS auto shifter
Hays convertible clutch
Yea, that about sums it up...
Old Sep 25, 2002 | 02:45 PM
RONIN's Avatar
Tetris on a stick
It is a stock cam, not an aftermarket adjustable one. I did the same thing, turned the gear's bolt to move the cam. Unfortunatly it snaped in the process. -- My guess would be, since the bolt's thread is one size, and before that is about 2mm larger it allowed for play on the bolt as I was moving the cam. I must have shifted the weight on the wrench just enough to break it.
if you pull the cog off the cam you will see a little piece of metal, its a key. you have to change your cam cogs (aftermarkets are called cam gears) or you have to slip the timing belt with the cams at tdc and knock them over a tooth.
Eat a live toad every morning, and that will be the worst thing to happen every day.
