crx with b20?
Old Sep 23, 2002 | 08:57 PM
Sneakin Deacon's Avatar
PSSHHH x2
high 13's?
El Pendejo Loco
2002 Suzuki Hayabusa
1507 "dry" block
Brocks megaphone
Spencercycle 10" swingarm
MPS auto shifter
Hays convertible clutch
Yea, that about sums it up...
Old Sep 23, 2002 | 09:13 PM
PSSHHH x2
i wouldnt know....id go turbo...but thats just my opinion, i wouldnt even consider a supercharger and if i did it'd be the vortech because it seems to make pretty good gains...i think ull have traction problems to begin with but nothing a set of slicks couldnt fix, plus the LSD will help alot too...
if he wants to make it an all out drag car...tear the shell apart, 8.5:1 compression pistons, some sort of turbo setup @ 15psi, bore the block to like a 2.3, and itll be more then quick... but its all about budget...
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
Old Sep 24, 2002 | 04:35 AM
hybridcrxs3's Avatar
lol everything you said is wrong. on a full drag car you don't want 8.5:1 is way to low even for a street car 9.1 is the lowest to go, more like 10.1 also a drag car should run more than 15psi cause 15 is to low more like 20+ on a big t4 turbo. and third it's impossable to bore the block to a 2.3 i'll let you hang yourself on that one. and teg penis my freind has a eg with a b20 with b16 tranny i/jdmh/e and a ls ecu stock 8.8 comp, he runs 14.5 full weight so in a stripped crx and higher comp 13's easy with 2.0 or better 60'.
Old Sep 24, 2002 | 08:08 AM
PSSHHH x2
well if he has enough money to fix stuff then yea go ahead, the b20b has 8.8:1 compression stock, which is good for a turbo setup, the b20z has 9.6, i dont know why you would go 10:1 but hey, ive never built a drag car before so... just been my experience you dont want to have high compression with lots of boost...and i was under the impression jun made a 2.2/2.3 stroker kit for the b20
and with this: http://www.goldeneaglemfg.com/sleeves.htm he can run up to 40psi
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
