cooling porblems on B16...II
Old Sep 23, 2002 | 09:19 AM
KJ's Avatar
KJ
bored at work
Replace with a thermostat from Acura, don't use NAPAQ or Discount stuff.
Replace the water temp sensor, it is the nipple looking plug on the side of the head that is removed with a long 12mm socket. I've seen them go bad and give false reading before. All of them are the same so just find one off of almost any Honda.
Old Sep 24, 2002 | 07:08 AM
KJ's Avatar
KJ
bored at work
No I just meant a genuine Honda thermostat. If you already have one then good. Try the temp sensor.
Old Sep 25, 2002 | 07:05 PM
UnderPSI's Avatar
When you felt the radiator hoses, were they pressureized? The hoses should be under pressure after the engine is at operating temp. Other wise the radiator cap may be bad or you may be low on coolant or have a leak somewhere. Also you said that you could hear the radiator boiling? If that is the case then the guage is probably not wrong. It is probably over heating. If the upper hose was noticible hotter than the lower hose then you may have a clogged radiator. Also check for any excessive bubbles in the radiator with the cap off and engine running. This may indicate a blown head gasket or worse.
Old Sep 26, 2002 | 10:05 PM
ibjhb's Avatar
Could you gauge just be faulty?
James
