CRX Motor Swap Q's
What is all needed to complete a D16Z motorswap into an 88 CRX HF? I have a complete 95 Del Sol Si front clip. (OBD 1) Is it a simple bolt in procedure or is there some special wiring involved? What axles, etc will I need to use? TIA
you use the delsol.......... block,head,intake,header,clutch,flywheel
and use the crx ..........tranny ,cvs,injecters,mounts,wiring,(get a si ecu and map senser)
AND THEN IT BOLTS/WIRES RIGHT IN LIKE IT GREW THERE
ps several options for dizzy
813-377-5505
Guest
Posts: n/a
I have also _heard_ of (Altho never seeing) using the 4wd tranny for the CRX Si motor. Suposedly they bolt up. I don't know how strong they are, but 4wd would be pimp in such a small car. Add 150whp and it'll be owning some crazyness out on the road/track.
Originally posted by "MR2driver"
What about using the Del Sol's tranny and/or axles? I would like to use as much as the Del Sol componants as I can. Taking the wiring harness out and switching ECU's isnt a big deal at all. If there is wiring involved that isnt a big deal either. I am just looking at how I can do it with what I got with as little purchasing extra parts as possible. Can it be done with the Del Sol's tranny with getting custom shiza?
Originally Posted by Lil Ze
Florida is the new Miami through and through.
