D16Z6 and D16Y8
Old Sep 16, 2002 | 10:28 AM
Sneakin Deacon's Avatar
PSSHHH x2
as far as i know you can, ive heard of people doing mini-me's with that setup
El Pendejo Loco
2002 Suzuki Hayabusa
1507 "dry" block
Brocks megaphone
Spencercycle 10" swingarm
MPS auto shifter
Hays convertible clutch
Yea, that about sums it up...
Old Sep 16, 2002 | 11:03 AM
art's Avatar
art
E=MC-hammer
you most certanly can its not a overall HP gain but it will give you a notciable power ban increase its all in the way the head was made as in the Y8 tends to circulate the A/F around oposed to just dumpin it in like the stock z6 head i have been wanting to change my D16z6 head for the Y8 for some time now but I lack the funds and the time to do it.....but if you have the opertunity to I would as well as change out the rods and pistons you can use the rods out of the ZC and the pistions from a 90-91 teg for better comprestion and androds for better hp handling
I hope this helps you out a little
art
IM IN VA BITCH!!!!!!
www.rccustomz.com
Old Sep 16, 2002 | 07:22 PM
civicracer901's Avatar
B16ACRX
i understand everything except what does hot tanked mean?
Old Sep 16, 2002 | 08:23 PM
crix's Avatar
:mugen member:
How much did you pay for the pistons,The reason Im asking is because Im looking to do it to mine!
Old Sep 17, 2002 | 08:00 AM
shadowboy's Avatar
insert witty retort here
art
take the rods out of an 86-87 teg. they are pretty much identical to ZC rods and more readily available.
(the 88-on D16 rods are weaker)
they are beefier than most of the SOHC D16 rods, and will fit right in.
i dont think the 90-91 teg pistons will fit as the bore size is much larger than the D16.
the 90-91 teg have an 81mm bore and the D16s have a 75mm bore.
use the pistons out of an 88-89 integra (factory 9.5:1 compression)
the D16Z6 and D16Y8 both have a smaller combustion chamber volume than the D16A1, so 88-89 integra pistons will boost compression nicely.
Shawn
The answer to your question is sqrt(pi)
Old Sep 17, 2002 | 08:58 AM
foesicks's Avatar
Use ls rods, they are way better than zc crap, but their is some machining required to make the rods fit the crank.
