SOHC Bored motor + boost...
Old Sep 16, 2002 | 02:50 PM
chet's Avatar
All Aboard
boost + stock d-series bottom end equals broken rods.
like eric said, save for a b-series motor, they're stronger and more reliable.
Old Sep 16, 2002 | 11:08 PM
StreetDriven's Avatar
I <3 your mom
Originally posted by "CronicBurn"
Forged rods are hard to break. Boost or not.
Right now im not going to run that much boost. 7-10psi.
Once I bring up a good amount of block stability (Rods+sleeve+girdle) Then I'll bring the boost near 20.
Should be easily in the 12's.
Hey man more power to you, I think you should rock it...different is good
Rich
Old Sep 17, 2002 | 08:11 AM
shadowboy's Avatar
insert witty retort here
that is a dyno plot of a turbo 89 integra
only thing done to the bottom end are arias pistons and shotpeened factory rods.
the question is which D16 rod are you gonna use?
Shawn
The answer to your question is sqrt(pi)
Old Sep 17, 2002 | 09:02 AM
foesicks's Avatar
Not really, bad tunning + boosted = broken rods, thier are alot of people running 10 psi on stock bottom end d series with no problems.
Old Sep 17, 2002 | 03:26 PM
Bill's Avatar
Livin' in Seattle
With the right parts a boosted D-series motor can be pretty rugged. The great part about it though is you can pick up parts, hell a whole damned engine for under $500. Don't see that happening with B-series do ya?
As for the overbore, .02 isn't anything more than a cylinder cleanup so I wouldn't worry.
