Running too Rich
Old Sep 15, 2002 | 01:34 PM
crix's Avatar
:mugen member:
Default Running too Rich
I had a problem with my main relay,it was not turning on my fuel pump,so I hooked it up so it runs all the time,I ve tried switching the m/relay and it still did not work properly,My question is How do I FIX THIS problem,Could I buy a fuel pressure reg. to resolve this nightmare?
THANK YOU for whom ever helps!
Old Sep 15, 2002 | 02:39 PM
99B16Si's Avatar
get a new relay
Old Sep 15, 2002 | 04:06 PM
crix's Avatar
:mugen member:
I have a new relay,It still does not work ............
Old Sep 15, 2002 | 05:41 PM
crix's Avatar
:mugen member:
It does not have power at the fuel pump,so I am going to get an ohm meter and check for volts at the relay,The relay was used when I bought it,Could be bad,I hope so,Where can I get a brand new one for fairly cheap?
ps The wiring is perfect
