Easy brake question..
Old Sep 13, 2002 | 06:03 PM
civicracer901's Avatar
B16ACRX
Default Easy brake question..
ok i was changing pads on the hatch today and found out that the seals were bad around the pistons in the cailpers both front sides. I replaced the seals and had to bleed the front two brakes right? Iam still not getting the pressure that i want or thats supposed to be there. I might have let air get into the brake master cynlinder so do i need to bleed all four now? I know there is a certin order from left to right or left passenger side to front driver side or does this matter? please help.
Old Sep 14, 2002 | 04:49 AM
Bill's Avatar
Livin' in Seattle
Did you replace just the boot or the seal as well?
Teg - LF,RF,RR,RL
Civ - RR,LF,LR,RF
Old Sep 14, 2002 | 01:21 PM
B16ACRX
i replaced the seals around the pistons thats it . I have very little brake pressure and also i let the fulid in the master brake cynlinder go very low maybe enough to let air in the sys. Do you know if i have to bleed all 4 now.
