help no fuel pressure or spark
Old Jan 14, 2011 | 07:35 PM
surfrevo's Avatar
Exclamation help no fuel pressure or spark
ok i drive a 91 integra with an obd2 swap and obd1 conversion the car was running good sat but at about 125 it would cut out for about 5 sec then come back and now 2 days ago it just cut off completely theres no spark or fuel pressure i tried 3 diff main relay one was rebuilt and i tried a diff ecu still the same please help i have no transportation to work thank you
Old Jan 14, 2011 | 09:02 PM
BoostedRacerDad's Avatar
Pops
Im thinking bad ECU ground on thermostat housing, bad ignition switch. ALL Bad main relays. Do these test and click to the right if you get a NO
Honda Acura Starting Problems Repair Guide, Main Relay Locations
Jdm b18c R LSD CRX si
TR "Old Skool EF" Member #96
JoKie TuNinG
RANGCRX BUILT TYPE R
StricKlyMT
727-510-6301
