not as smart as a thought ls swap into eg help
Old Jan 12, 2011 | 06:14 AM
jade's Avatar
Default not as smart as a thought ls swap into eg help
ok i just swaped a ls into my eg hatch it cranks up fine and idles good but when i put it into gear to drive it wants to cut off when it starts to cut off i let off the gas and it idles fine it only happens when i press the gas down fast. i checked already to see if the map and the tps plugs where switched and there not please need help thank you
Old Jan 12, 2011 | 06:17 AM
jade's Avatar
sorry not as smart as i thought lol car is drivering me crazy
Old Jan 12, 2011 | 06:34 AM
BoostedRacerDad's Avatar
Pops
Is it throwing any codes?
Jdm b18c R LSD CRX si
TR "Old Skool EF" Member #96
JoKie TuNinG
RANGCRX BUILT TYPE R
StricKlyMT
727-510-6301
Old Jan 12, 2011 | 07:16 AM
rangcrx's Avatar
engine building &best
Try another trottle body then..most gas problems start with the tps.or in the distributor
i love AUTOZONE
Old Jan 12, 2011 | 09:31 AM
jade's Avatar
no but think the guy b4 me may have taken the check light bulb ill check any body else have any suggestion
Old Jan 12, 2011 | 06:02 PM
91boostedef6's Avatar
Alexslow1k
Might want to check your fuel pressure regulator
Old Jan 13, 2011 | 12:01 AM
bigpudge's Avatar
lol i have a similar problem like yours most likely your map sensor could be deffective
TR "Old Skool EF" Member #190
