max hp on pump gas?
Whats the max WHP you can run on pump gas (93 octane)? What about E85?
If it makes a differance, set-up I'd be considering consists of:
Mildling ported/polish A6 Head
Vitara Pistons + FJ-D Custom Spec Rods
T3/T40E 57 Trim .63 a/r
~10:1 compression (milling head alot)
Would like a dyno that looks like: http://dynos.evans-tuning.com/wp-con...1/FR-Pinks.jpg
More info is needed regarding the engine...
A6 head? Bore/Stroke? Exhaust/Intake mani? Downpipe?
Vitara pistons @ 10:1 ?
Your turbo would most likely run out of air before you run into any fueling problems.
Custom Top mount, design would be somewhere between Hytech Wastegate Priority design and your standard top mount design. 3-4" downpipe/exhuast.
Either a ported Z6 mani or a ported Edelbrock performer x
Wacking an A6 head ~0.100" get you to just under 10:1. Considering dropping compression if I can make more power though.
Thanks.
D16A6 Block, A6 head (maybe Z6 head, idk yet). 75.5mm pistons
Thanks.
Thanks.
That doesn't mess with timing since its a OHC motor????
1999 Honda Civic Si
1984 S10 355 small block drag truck
1971 Toyota Pickup Converted 4x4
TR em1 crew #43
1999 Honda Civic Si
TR em1 crew #43
I know part of it was using a B16 Water Pump Pully (22 teeth vs 19 teeth, iirc).
Here's a GREAT thread on milling the head alot:
Milling the head ALOT and problems related to it - onecamonly.com
4whp
seriously dude, build the engine, let us know what power it makes.
Honda-Tech > TampaRacing
TR "Old Skool EF" Member #666
