block and head combo question.......
Old Jan 8, 2011 | 06:11 PM
b13steve's Avatar
Thumbs down block and head combo question.......
im wanting to know if this combo is worth the effort. b20 block with ls (a1) head.my understanding is b20 has more torque as ls has more top end power. i havent gone as far as getting specs of each ( bore, stroke valve size, ect...). car has light mods consisting of full exhaust, cai, blox intake mani, 63mm tb, chipped ecu. exploring my options.
JDMinnovations hollywood, fl
93 del sol.....z6 on 8psi......201...daily beater
91 talon tsi.....25psi.......467...weekend sleeper
I do DP to MP swaps and full obd-1 for EF
352-364-6384
Old Jan 8, 2011 | 11:12 PM
chi town brat's Avatar
! Ne shab'rud'ni !
honestly the LS head isn't worth putting any money or time into unless you were in a stock autocross or road race class and were going within the rules for building the engine. it doesn't flow well as it really was designed for economy, not even a port and polish will do much for it.
if you want to do a B20 block then spend the money to get a B16 head and put the money into the head. i can't speak enough of the power made from putting the money into the right parts and labor.
Old Jan 9, 2011 | 05:36 AM
b13steve's Avatar
thats what i kind of figured. i was also leaning twards ls-v also. and when it is pulled down going to have some light machine work to the head so it flows better
352-364-6384
Old Jan 9, 2011 | 07:22 AM
! Ne shab'rud'ni !
If you already have the b20 block go for the b20 vtec.
I see you are in Hollywood, FL so you are close to Stuart. There is a shop there that milled, cut the valve guide seals, and angeled valves. I cannot remember their shop name but they do all the headwork for Titan Motorsport in Orlando. I would highly recommend them to do the headwork. The price was very reasonabile as well.
As for the pnp work I have my friend David do that for me in Rockledge.
If you are interested I can get the shop name that is in Stuart for you.
Old Jan 9, 2011 | 09:49 AM
custom240sx's Avatar
DC Crew Member #1
LS heads are the same as the b20 head minus the p8r head which has vtec sized intake valves. The combo wont do anything special for you. No extra power will be obtained.
Old Jan 9, 2011 | 12:29 PM
b13steve's Avatar
no, i dont have the block. im poking around at some ideas before i start putting money in a build. im wanting to build a nasty non-vtec, then build up a vtec.
352-364-6384
