car want pass 4000 rpms
so heres my car 91 civic std
d15 motor tranny
pgfi
obd1 ecu and dizzy
so i just got the motor in and it want pass 4000 rpms its on a p06 with a d15 dizzy bolted to the head
basically stock motor just pgfi and obd1
whats usually the cause of this?
it would be helpfull if u could call me or just post it on here 8137707861
d15 motor tranny
pgfi
obd1 ecu and dizzy
seffner meet getting started so click here to get in
https://www.tamparacing.com/forums/local-events/745189-seffne-meet-lets-get-something-started.html
*ad removed*contact admin@tamparacing.com to ADVERTISE on here....
https://www.tamparacing.com/forums/local-events/745189-seffne-meet-lets-get-something-started.html*ad removed*contact admin@tamparacing.com to ADVERTISE on here....
try to see what codes it throwing if it is throwing any when its like that it means the ecu in in limp mode its throwing an important code my car would do that when my injector plug would get loose so check all ur main connections like injectors dizzy maybe somthing is bad or there is a bad conection somewhere
K*Squad
K*Squad
You need the codes to figure this one out.
Did you drive the car? 3500rshared_pm is limp, 4000rshared_pm sounds like launch control. post codes
Jdm b18c R LSD CRX si
TR "Old Skool EF" Member #96
JoKie TuNinG
RANGCRX BUILT TYPE R
StricKlyMT
727-510-6301
JoKie TuNinG
StricKlyMT
727-510-6301
ok thanks everyone and flat rex if i cant find out what it is how m,uch for u to fix it for me?
iu dont drive it basicaaly i bought it and its been this way even before the new motor
check all wiring 2-3 times even if u swear u know u plugged em in tight/correctly, al grounds and is it the same ecu as before the new engine?
TR "Old Skool" DA member #60
Santos618 - Xbox 360 gamertag
GTA4
Forza 4
Madden 12
open to any good online games, i just suck at shooters lol
GTA4
Forza 4
Madden 12
yes same ecu!
tick tock tick tock
