Ls startup problem obd0 ecu code 5
on
Ok tr im back again for some advice and help first off I have a 88 ef si obd0. I finished my swap and ran fine for the first day out until it just shut off on me after a 15min drive. couldn't get it to turn back on until the motor was completely cold so I drove it back and barely made it .and now when I try to get it to turn on I have to hold on the gas for it to cut on but when I let go of the gas it just dies and keep getting engine code 5 which I know it stands for map. can someone tell me what could be the problem could be? pics could be taken if needed its my only car i need running asap
TR "Old Skool EF" Member #190
What color are the three wires going to MAP?
Any vacuum leak or bad hose?
Jdm b18c R LSD CRX si
TR "Old Skool EF" Member #96
JoKie TuNinG
RANGCRX BUILT TYPE R
StricKlyMT
727-510-6301
JoKie TuNinG
StricKlyMT
727-510-6301
on
I knew you will come to the rescue boostedracerdad lol you had help me before I can send you pics if u want but who ever had the car before me had cut the map wires but the colors going to the map are 1)green/white 2) blue/red 3) red/green but now its giving me another code the computer blinks with 1 long pause and 7 blinks after that what could that be?
Pretty sure you have the TPS and Map sensor plugs backwards. I bet you are throwing code 7 and code 5. Try swapping and resetting Ecu.
When the swap was done was the two outer TPS wires swapped?
JoKie TuNinG
StricKlyMT
727-510-6301
JoKie TuNinG
StricKlyMT
727-510-6301
JoKie TuNinG
StricKlyMT
727-510-6301
JoKie TuNinG
StricKlyMT
727-510-6301
