are bseries gears/syncros interchangable??
i have a hydro gsr tranny that is busted to shit
i want to use the 1st gear from the gsr i have a LS 5th gear
and then order del sol 2,3,4 and get a quaiffe.
i just want to make sure the gears/syncros are gunna fit.
yes the gears will interchange between different hydro b trannys....but there is a difference between some of the selelector hub/syncro assemblies...you need to use the shift fork that goes with the gear
