valve to piston clearance....
Old Sep 10, 2002 | 05:38 PM
Gotin's Avatar
Sayien
Default valve to piston clearance....
a situation came up with my head. It has been resurfaced .010 when i recived it. Now i found a little "scar" close to the cumbustion area, the way to fix this problem is to have it resurfaced again .010. Now this will put the head at -.020 from stock. My question is, will .020 be to much on the B16a motor with the factory head gasket while running your Spec B cams? Will i have valve to piston clearance issues? Thanx
BJ
Old Sep 11, 2002 | 11:24 AM
Gotin's Avatar
Sayien
Toda Spec B's
Duration (lift mm)
Intake 250(11.0)-295(12.0)-250(11.0)
Exhaust 250(11.0)-285(12.0)-250(11.0)
Old Sep 11, 2002 | 04:55 PM
Gotin's Avatar
Sayien
thanks for the info iam probally going to go for it. anyone here have experance with them?
Old Sep 12, 2002 | 07:07 AM
KJ's Avatar
KJ
bored at work
Well if you are worried just install the cams and do a clay check for clearances. If it checks out you're good to go, if not sell the cams or sell your head and be glad you didn't grenade your motor.
Old Sep 13, 2002 | 09:00 AM
Gotin's Avatar
Sayien
thanks people
