need help. throw out bearing rubs on pressure plate
Old Jan 4, 2011 | 12:43 PM
bwhiteboy1020's Avatar
Question need help. throw out bearing rubs on pressure plate
okay i have a problem thati jus cant seem to slove. i have a 95 gsr integra. when i bought the car the owner told me the only problem it that the throw out bearing rubs on the pressure plate. so i have bought a new clutch kit. (pressure plate, clutch, both bearings). that didnt slove the problem. so i changed the slave cylinder. and then the clutch fork. still nothing. i blead the lines over and over, and have no leaks. does anyone have any ideas?
Old Jan 4, 2011 | 05:46 PM
MotoX's Avatar
Master Tech
ummmmmm, explain more.
Old Jan 4, 2011 | 06:05 PM
Nycist's Avatar
NY Till I Die....
Fuck. lol.
Im laughing hysterically.
Originally Posted by Lime_Green_Hatch
$350,000 in 2 years... and all they had to show for it was some shitty hondas, lol.
R.I.P. Steven Daniel Berry a.k.a. Bush
Old Jan 4, 2011 | 06:13 PM
sean83's Avatar
you can hear it rubbing? does it go away when you press the clutch pedal? if so its your input shaft bearing. mine does the same thing. was caused by busted axle seal
Old Jan 4, 2011 | 11:50 PM
okay. when i puch the clutch pedal in no noise. but when you let it out you can hear it rubbing. and when you drop the tranny. you see the ring from where the bearing has been rubbing.it does the same when the car is in gear. after i put it in gear it will rub. ive adjusted the clutch pedal in and all the way out, nothing..
Old Jan 4, 2011 | 11:51 PM
push* sorry about that & im dropping the tranny today again. so i will check out the shaft and all the seals.. thanks for the info.
Old Jan 5, 2011 | 02:26 PM
sean83's Avatar
Save ur time. Unless u know how to rebuild ur tranny. The bearing is on the inside. Imleaving mine until I get a new tranny
Old Jan 6, 2011 | 02:29 AM
rangcrx's Avatar
engine building &best
your bearing is supposed to rub on the presureplate its always in contact...^like he said your tranny is fucking up not the clutch.if your getting a whineing sound
i love AUTOZONE
