shift linkage
Old Sep 9, 2002 | 10:23 AM
Sneakin Deacon's Avatar
PSSHHH x2
Default shift linkage
ok i popped off the retainer clip where the linkage connects to the tranny, but i cant seem to get the pin to budge at all...what am i doing wrong here? its a 90 std tranny that im pulling the linkage from, if theres a difference...
El Pendejo Loco
2002 Suzuki Hayabusa
1507 "dry" block
Brocks megaphone
Spencercycle 10" swingarm
MPS auto shifter
Hays convertible clutch
Yea, that about sums it up...
Old Sep 9, 2002 | 01:42 PM
KJ's Avatar
KJ
bored at work
get a bigger hammer and don't be afraid to really lay into it(don't miss though). You might also want to try some pb spray. If you still can't get it find someone with an air hammer and appropriate sized punch bit. I have in my time probably removed over 50 linkage pins and the hammer and spray has worked every time. Good luck.
Old Sep 10, 2002 | 02:00 PM
PSSHHH x2
...this bitch is welded in or something, i took a damn mini sledge to it and it aint budging...
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
Old Sep 10, 2002 | 02:41 PM
blackbean92's Avatar
man put some weight into it or are u just that weak
better get stile to hit it for u
Old Sep 10, 2002 | 03:21 PM
Moriarty's Avatar
Take one of the bolts holding your A/C compressor (assuming you have A/C) to it's mount, and use it in combination with a 5lb sledge. Even if it doesn't look like the pin is moving, it is, it just takes a lot of effort. Worked for me.
=========|Chris|=========
Old Sep 10, 2002 | 05:20 PM
PSSHHH x2
... bet you cant guess what the car was named...
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
Old Sep 11, 2002 | 04:00 PM
PSSHHH x2
nah, we couldnt get monogonaherpacyphalitis to fit on the back windshield, so we named her Chlamydia
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
