KYB GR-2 shocks for me teg???
Old Sep 11, 2002 | 12:35 PM
Tits McGee's Avatar
is cooler than you
I DISLIKE the Neuspeeds, cause the drop was way more than they said. The Sports were supposed to be 1.7", ended up being over 2", so now I'm screwed until I get new springs or coil overs.
Pro-kit's are like 1.2" I think.....Sportlines are 1.75"....and the Road-Race ones are like 2.25".
When I switch, I'm most likely going with the Pro-Kit.
Old Sep 11, 2002 | 02:11 PM
Sleeping_92_SI's Avatar
I kill 32-bit ECUs
do you have a swap ?? excess weight can cause a car to drop lower than they say ?? neuspeed is usually within a 1/4 inch margin of what they say unless you have a collapsed strut or on your stock struts the springs will take excess wear and probally drop you car more.
I say Get Eibach Pro's like leslie said. or save and get a true coil-over
set-up (you get what you pay for) !! and 370 for the struts and springs is a nice price. just call them ask how much more for eibach.
Also company called RED's is featuring a full coil-over set-up for 400. they don't compare to tiens but, a hell of alot better than springs or like ground control. also you will also have adjusability options. and this is a true coilover set up !! i heard a couple rumars of it. so far high remarks but, how picky can you be for 400 bucks that will buy you about ONE TEIN !!!
Anthony
Drunmann Tuning's Scoob: 2.55 liter-6spd swapped Bugeye, fully built w/280 cams and a rotated Precision-6266
DD: 2010 MazdaSpeed3: Fully bolted and tuned
Drift Missile: S13 DOHC swap, welded diff = slidetastic
Bicycle: Kawi 636R.
Old Sep 11, 2002 | 08:28 PM
Tits McGee's Avatar
is cooler than you
No swap for me. Only reason I can figure is because I have a 4 door Integra, and it's like 100 lbs heavier than the 2 door.
Old Sep 12, 2002 | 05:58 PM
TampaStig's Avatar
AEG
so since i have a RS which is lightest of the tegs - wouldnt i get the claimed drop of 1.75?? or even less?
Originally Posted by shinmei2006
if you want to have fun get the s2k, if you want to go fast in a straight line but get made fun of in everyday traffic, get the srt4
Old Sep 12, 2002 | 06:00 PM
TampaStig's Avatar
AEG
Old Sep 12, 2002 | 08:23 PM
Tits McGee's Avatar
is cooler than you
Im sure you won't get less....at least not with the neuspeeds. I know of several people who used them and got more drop than they wanted. but it's up to you. good luck with whatever you choose.
Old Sep 13, 2002 | 05:11 AM
  #17 (permalink)
ibjhb's Avatar
Anthony
I've heard of these before also.... they're *supposed* to be pretty good, especially considering their cost....
James
