gs-r block-b16 head?
Originally posted by "CronicBurn"
Thanks for the info... How does the head raise compression by adding cc's to the head... How did you figure it would raise compression by .2cc? What formula or what not did you use?
Thanks.
Thanks.
Try This:
Compression Ratio = Vbdc = Vcyl + Vpc + Vdh + Vcch_
....................................Vtdc.......... ........Vpc + Vdh+ Vcch
..................................2............... ....................2
which equals II(B/2)_ S + Vpc+ Vpc + II(B/2) _D +Vcch_
.............................................2
..........................Vpc + II(B/2) XD + VcchWhere:
B = bore,
S = stroke,
Vbdc = volume at bottom dead center,
Vtdc = volume at top dead center,
Vcyl = total cylinder volume,
Vpc = volume of piston crown,
Vdh = volume of deck height,
Vcch = volume of combustion chamber in head,
D= deck height.
After you think you got that figured out, go search the web for a "CR calculator" like http://www.smokemup.com/auto_math/compression_ratio.php
Also, it's common knowledge that the ITR head is mildly ported and pollished... but 5.25% Where did you get this?
Also If the ITR has the same cc's as the Si(B16a)... Then how would it not raise compresion by .2cc?
The b18c5 flows better than the B16, but it doesn't raise the CR any (compared to the B16!) Understand now?
Charles
[/quote]
My Blog: www.HotRodCaddy.com
Guest
Posts: n/a
Okie. As I have not saved the formulas and such. Thanks.
As you quoted you said. "Doesn't raise the cr any". By any would mean compared to original. At least that's how I took it.
Thanks for your info, altho you seem to be a little condecending about this.
Okie. As I have not saved the formulas and such. Thanks for your info, altho you seem to be a little condecending about this.
Charles
Blah Blah Blah Blah.....
When you got a car with these characteristics... Look me up.... 4.25 @250 baby....
Especially you feriotechbia.
FMF
FMF
I own Cronic Burn, Chron, @whatever car he's got...
Originally posted by "CRX/NSXhybrid"
...go to your gm board, and yea there is a couple replacements for displacement...
The saying (from the 90's): The only replacement for displacement is forced induction.
Class Dismissed
Charles
Guest
Posts: n/a
Originally posted by "RiceRocket"
The saying (from the 60's): There is no replacement for displacement.
Class Dismissed
Charles
Class Dismissed
Charles
someone got straight flammed. it is true though.
