hybrid tranny
Old Sep 5, 2002 | 11:47 AM
2qk4u's Avatar
Default hybrid tranny
b-series tranny
what would be the best gears to put in it if i had the time/money
for all motor
i will replace everylast gear to achieve the best acceleration for 1/4 times
Old Sep 5, 2002 | 06:16 PM
2qk4u's Avatar
its gunna be all motor ls
like hardcore over 12:1 compression
stg 2 cams
hondata
my dad is building it
but its gunna be my gsr tranny
someone told me b16 or ITR final drive and i should get the LSD for like 300 or so.
Old Sep 5, 2002 | 06:35 PM
b16aRacer's Avatar
Moon Equipped
I would say Si or ITR 1-4th gears, with an LS 5th and a Si/GSR/ITR 4.40 final drive.
'00 FBP Si
Sebring rule in effect
Old Sep 5, 2002 | 07:09 PM
2qk4u's Avatar
i looked at some charts and GSR and itr 1st gear are same ratio
im gunna do this
GSR 1st
del sol vtec 2,3,4
LS 5th
itr lsd
i have the 1st and 5th gear so i need 3 gears
and what syncros can i use? can i use the gsr syncros?
and will all these gears fit correctly into the tranny?
Old Sep 7, 2002 | 04:34 PM
specie's Avatar
use the jdm itr final drive (I think it's 4.7). I'm new to the hydro/obd stuff. Also, I think ATS (something like that) has a 4.9. Again, just saying there is stuff like this out there, not that the info is completely correct.
Old Sep 8, 2002 | 07:20 AM
Sleeping_92_SI's Avatar
I kill 32-bit ECUs
Originally posted by "Mr Self Destruct"
get a Prodrive 5.1 final drive and you're scraight pimpin yo!
ats 1-2, 3-5, 4.9 final, itr limited
Anthony
Drunmann Tuning's Scoob: 2.55 liter-6spd swapped Bugeye, fully built w/280 cams and a rotated Precision-6266
DD: 2010 MazdaSpeed3: Fully bolted and tuned
Drift Missile: S13 DOHC swap, welded diff = slidetastic
Bicycle: Kawi 636R.
