Z6 into Crx Help
Old Dec 14, 2010 | 04:09 PM
VERYslowREX's Avatar
Default Z6 into Crx Help
I'm swapping a z6 into my rex and keep running into dumb shit. I think I have all the wiring figured out thanks to a few of you that replied to my other thread. Now here is the new problem.
I'm keeping my a6 cable trans instead of converting to the hydro. I pulled both transmissions off both motors tonight and everything looked like it would line right up and bolt onto the z6 block. We had a little trouble getting the trans lined up at first but we eventually got it on and bolted it up. Thought it was good. But the clutch doesnt feel like its engaging.
I did keep the clutch on the z6 that the hydro trans was bolted to. Should I have swapped the a6's clutch to the z6 block? Are they not the same clutch? If anyone could get back with me on this tonight I would appreciate it, I'm hoping i can get this trans on the z6 tonight so I can get the motor back in the car and then figure the wiring out and go!!
Thanks in advance...
91 Crx Si - Pearl White
Complete Z6 Swap - In Progress
Z6 Budget Build - Coming Soon
Old Dec 16, 2010 | 06:29 PM
HondaHouse's Avatar
IS AT THE DEALERSHIP NOW
88 clutches are the only different ef clutch.......89-91 and all hydro single cam clutches have the same spline count........as long as you have an 89-91 cable trans, then you shouldn't have a problem using the hydro clutch....
Mike @ 239-851-3234...anything pertaining to HONDAS
Originally Posted by Jordan T
sounds like you have a problem, your car is a mitsubishi, try replacing it.
Old Dec 21, 2010 | 07:43 AM
M3 Bl4ziN9's Avatar
can u put a stock clutch in with an aftrmrkt flywheel?
Old Dec 21, 2010 | 04:14 PM
HondaHouse's Avatar
yeah....as long as its the proper diameter for flywheel
Old Dec 22, 2010 | 10:09 AM
89crxsir's Avatar
Did you try adjusting the clutch cable???
SEE NO EVO HEAR NO EVO!
If i put half a tank of Shell V power, and half a tank of Chevron with Techron. Will i get v-tec??
