How to fix my automatic revving problem on my 97 Prelude
Old Dec 3, 2010 | 01:02 PM
HondaAboveAll10's Avatar
I love my 5th Gen
Default How to fix my automatic revving problem on my 97 Prelude
Im sure alot of you guys get this problem, or have had this problem once in your life, but because of the darn cold weather my car revs from 1000 rpms to 2000 rpms and back and forth on its own. I know its the Air Control Module, but ive never fixed this thing and its annoying, any tips? Thanks in advance
Old Dec 3, 2010 | 07:10 PM
AccordTypeR's Avatar
there are to things that usually cause this in a honda, the IAC motor( idle air control) and the tps(throttle position sensor), try replacing the IAC first its less expensive and usually thats what is wrong, very common honda problem
Old Dec 4, 2010 | 08:13 AM
SloCivic's Avatar
hope this helps.
How To: Clean IAC Valve (smoothes out rough idle) - Honda Prelude Forum - Prelude Online.com
Old Dec 4, 2010 | 03:12 PM
Durdan's Avatar
No Ants Drift Member
what happens is the fast idle valve in the throttle body becomes stuck. this is a mechanical idle control valve that is controlled by a temperature sensitive spring heated by those pecky coolant lines going through your throttle body.
it's supposed to close when the engine is warm and your IACV takes over from there, in a nut shell.
well, when it sticks, it's a HUGE vacuum leak that the IACV cant compensate for. on the bottom of the throttle body where the coolant lines go, you can unbolt the assembly and either weld the throttle body closed of make a block-off plate.
9 times out of 10, this solves the issue
RIP Tim. i miss you, buddy
Old Dec 5, 2010 | 04:16 AM
I love my 5th Gen
Thank you all, repped
Old Dec 7, 2010 | 11:46 AM
89crxsir's Avatar
I got the same problem on my DA, I'm gonna try it tonight!! FTW
SEE NO EVO HEAR NO EVO!
If i put half a tank of Shell V power, and half a tank of Chevron with Techron. Will i get v-tec??
