92 Civic, Radiator Hose Insert, Temp Problem
Old Nov 4, 2010 | 04:36 PM
Alswizzo's Avatar
The Underdog!
Default 92 Civic, Radiator Hose Insert, Temp Problem
I have a k24a2 swapped EG using Hybrid Racing Conversion Harness. I've been running it withouth a temperature reading on the cluster for a while now. No problem since im running the fan with hondata kpro at 182* no check engine, no overheating, no problem. I got tired of looking at the dead temperature gauge so i opted to fix this and for some added peace of mind.
I picked up a brand new cylinder head temperature sensor from honda
and a Blox water temperature adapter/radiator hose insert.
Before i do anything i take the blue wire labeled "temp gauge" and ground it and my needle reads Hot. Good
I install the sensor and adapter into place. Slap my blue wire on the sensor and ground the housing via screw for it to chassis.
My needle stays "Hot" and wont budge.
Thinking and Ruling things out. I swapped out the sensor with a known working one from my integra outside and nothing. The sensor in question worked flawlessly in the integra. That Rules the Sensor out.
I tried switching grounds, switching sensors, undoing and doing. Nothing!! it only Reads HOT!! i've spent my money, bought and leaked my antifreeze i just purchased and im very sad and upset.
Old Nov 4, 2010 | 04:52 PM
JDMjunkie's Avatar
you should just trade me lol gl bro
TampaRacing's DEAD!!
Old Nov 4, 2010 | 04:56 PM
JDMjunkie's Avatar
you should dtich that adapter that isnt really accurate i kinda had the same problem they sell a fitting that goes near were the fuel rail goes on the right of the motor kinda like a step down fitting to were you screw your temp guage at you can use a bseries one also and itll work fie that what i did with mine
Old Nov 4, 2010 | 05:17 PM
Alswizzo's Avatar
The Underdog!
i thought about using the step down adaptor that goes uptop by the manifold. But here's the question. What does the radiator adaptor have to do with it? it just holds the sensor in the water so you can get a reading. I dont see what the problem is there and its obviously delivering ground.
Old Nov 4, 2010 | 06:01 PM
JDMjunkie's Avatar
i dunno but everyone that uses them things dont keep um and beleave that the bottom hose is the one that really reads the tmp correctly if your using the adapter might wana go on K20A.org
Old Nov 5, 2010 | 04:24 AM
Alswizzo's Avatar
The Underdog!
The bottom hose actually stays cooler till the car warms up and thermostat opens up. The upper radiator hose gives you a better reading. I posted up on k20A, i even called Hybrid Racing. This shit sucks my dude, i just want my friggin Temp Reading on the GAUGE.
Old Nov 5, 2010 | 10:12 AM
BoostedRacerDad's Avatar
Pops
Spent about a hour looking at your Conversion harness vs EG cluster, wiring etc. looked at pinouts. I dont know either.
Jdm b18c R LSD CRX si
TR "Old Skool EF" Member #96
JoKie TuNinG
RANGCRX BUILT TYPE R
StricKlyMT
727-510-6301
Old Nov 5, 2010 | 12:15 PM
integra's Avatar
90% grind 10% sleep
what kind of material is the adapter made of? Just put it on the manifold,way cleaner look IMOP.
Honda Valve Adjustments 50$
I TUNE KPRO AND S300
I DO NOT WORK FOR FREE
Originally Posted by THE_ONE
Old Nov 6, 2010 | 12:08 PM
Alswizzo's Avatar
The Underdog!
i dont know what its made of, Some kind of Aluminum im guessing. It does look cleaner up there but i have the RBC manifold and its different then the usual pics you see online. It actually goes on my manifold and i have a bunch of lines that run through there and dont feel like rigging anything up. I guess i can try scraping the threads of the housing where the sensor goes in and on the ground thread also. Its Black not metal, idk.
