crx cuts off on startup
Old Oct 25, 2010 | 05:26 PM
M3 Bl4ziN9's Avatar
Exclamation crx cuts off on startup
i just got a 89 crx , it has a d16z6 sohc vtec obd1 n a couple of other mods , ive been drivin it for about a month now and she just started giving me startup probs. The needle for the r p m dsnt work and to me it sounds like the idle is way to low, when she cranks it sounds like the r p m drop a lil bit then she cuts off. i would have to try startin it 3 more times before it sounds like its idleing perfect n continues running
i talked to some dudes at autozone n they told me that if its ideling low i can only adjust it thru the ecu ..
i have no idea if thats what i gotta do but i just curious of what you guys think
Old Oct 25, 2010 | 05:30 PM
CleanCe1Wagon's Avatar
Love's making you mad!
honda tech.
| Right hand drive |
Old Oct 26, 2010 | 04:05 AM
chi town brat's Avatar
! Ne shab'rud'ni !
Moved to the correct section.
chi town brat
Admin
Old Oct 26, 2010 | 04:07 AM
! Ne shab'rud'ni !
if the engine is cold when you start it up then it sounds like your high idle control valve is going bad
this opens up first on start up which takes the r p m s high, then as the car warms up that closes and the idle air control valve (icv) takes over which is when you see the r p m s start to decrease, the icv is adjusted by a screw.
Old Oct 26, 2010 | 12:44 PM
M3 Bl4ziN9's Avatar
hmm so i would have to tighten up the screw to raise the idle ?
