accord MAP wireing
Old Oct 23, 2010 | 12:48 PM
96spydergst's Avatar
Question accord MAP wireing
I have a buddy who go screwed on a swap job, there is no map sensor at all. i need to know where to run the 3 wires to.
i think one is d17 on ecu but from left to right on the map plug what pin does it go in left middle right? and are the other ones power and ground? or if you can give me a diagram that would be nice.
please help
I believe in a lively disrespect for most forms of authority.
96 eclipse gst drop top sold
98 civic EX sold
94 civic EX sold
94 cx H22A1 whippin
Old Oct 23, 2010 | 02:28 PM
BoostedRacerDad's Avatar
Pops
1990 Accord CB7 F22B1 SWAP....3 wire MAP
YEL/WHT = D19 sensor 5v ref (+)
GRN/WHT = D21 sensor ground (-)
WHT/YEL = D17 sensor signal (+)
IAC
BLK/BLU = A9 sensor ground (-) (ECU)
YEL/BLK = A25 or B1 sensor, with ignition on = battery voltage (+)
Jdm b18c R LSD CRX si
TR "Old Skool EF" Member #96
JoKie TuNinG
RANGCRX BUILT TYPE R
StricKlyMT
727-510-6301
Old Oct 24, 2010 | 11:31 PM
Blue92ludesi's Avatar
map might be firewall mounted. map harness is not part of engine harness. check n make sure
Honda of Wesley Chapel Crew Member #1
TR 5th Gen Civic CREW Member # 07
TR H2B crew #2
__________________________________________________ _________________________________________________
Old Oct 27, 2010 | 11:16 PM
Hey blue...and thanks boost for that handy diagram.should get this car running right.
98 civic EX sold
94 civic EX sold
94 cx H22A1 whippin
