1999 Integra LS no spark???
No you wont lose timing, but there is no point now since you know timing belt is good cause you pulled cover.
Pull distibutor back off and spin taper gear and make sure rotor spins. If yes put srew back in and reinstall lining up taper to camshaft( only goes in one way) and try it again making sure rotor turns
BRB
coil for 25$.
IGNITION COIL acura INTEGRA 2001 2000 99 98 97 96 95 94: eBay Motors (item 130434828294 end time Oct-22-10 17:50:51 PDT)
Honda Valve Adjustments 50$
I TUNE KPRO AND S300
I DO NOT WORK FOR FREE
727-510-6301
Pulled the distributor and spun the back side, it moved the rotor, spun the rotor, it moved the back side...
So what does this mean... TO me it means something is broken lol, but really can something inside the distributor fail not allowing the rotor to spin. Doesn't make sense. Dizzy out, rotor spins by moving the taper, spinn rotor taper spins. Crank car, cams move crank move so should the rotor.
So is this meaning new coil? or is something larger at work?
I cant find a breakdown but looks like straight shaft with a couple of bearings. We both know will never start unless rotor turns...lol You need a dizzy!
Jdm b18c R LSD CRX si
TR "Old Skool EF" Member #96
JoKie TuNinG
RANGCRX BUILT TYPE R
StricKlyMT
727-510-6301
JoKie TuNinG
StricKlyMT
727-510-6301
Alright just didn't make sense that the shit spins but the rotor doesn't when the dizzy is connected. Will get a new dizzy, Advance is good with returns if that isn't the case LOL.
Just seems to weird. Reading and reading only says rotor don't move = internals wrong, not dizzy : ( What in the Dizzy can stop the rotor from moving when the engine is turning???
is the intake cam broken?????.......kinda what it sounds like to me........ crank with dizzy off head......have someone crank it for you and see if the cam is rotating.......
well let me know if she needs the belt changed....
727-510-6301
should be fine.
727-510-6301
