Identifying cable B16 transmission?
Old Oct 22, 2010 | 01:04 AM
Wisdom Teeth's Avatar
Default Identifying cable B16 transmission?
I called up Tampa Clutch because I need a new one, and they need to know exactly which B16 transmission I have because the input shaft differentiates between the two. Of course, I don't have the vin sticker for my tranny.
Is there any way to tell which is which without the vin sticker or actually removing the clutch first? I know its the normal, shitty, non LSD cable b16 tranny, I just don't know what to tell the dude.
Any help is appreciated. Thanks!
P.S.- If any of you guys have a manual pedal assembly for a CRX for sale, let me know! I cracked my second set today.
Rest assured, that with a heart that's pure, we'll be victorious and not let our hate get the best of us.
Old Oct 22, 2010 | 06:20 AM
DRMORTY's Avatar
Once Ruled The World .l..
Take it up there and compare them... LOL... GL
If it is B16 cable Trans, then it I think it is the same as a LS 90-91.
Hope that helps
TR
"Old Skool EF & DA Crews" Member #46
TR "Wagovan Club" Member #1
Old Oct 22, 2010 | 02:12 PM
zhillz's Avatar
Porno Music Producer
One has a smaller input shaft, and I don't know how to visual distinguish them. Measure yours and google it?
Old Oct 22, 2010 | 02:52 PM
integra's Avatar
90% grind 10% sleep
count the number of splines on the shaft.
Honda Valve Adjustments 50$
I TUNE KPRO AND S300
I DO NOT WORK FOR FREE
Originally Posted by THE_ONE
Old Oct 22, 2010 | 02:53 PM
Thanks you guys for the help. Much appreciated.
Old Oct 23, 2010 | 06:48 AM
BoostedRacerDad's Avatar
Pops
ALL 88-93 B-SERIES CABLE TRANSMISSIONS
all b-series flywheels and pressure plates can be interchanged. flywheel designs and weights vary.
A1/S1/YS1: 90-91 USDM b18a clutch splines and pilot bearing are unique. it has 20 splines and a smaller diameter shaft. cannot use 92+ clutch/pilot bearing. *optional LSD.
3.166
1.857
1.259
0.935
0.742
3.000
4.400
S1/J1: 90-91 JDM RSi/XSi, first gen b16. it has 20 splines and a smaller diameter shaft. cannot use 92+ clutch/pilot bearing. *NO LSD.
3.230
2.105
1.458
1.107
0.848
3.000
4.400
Y1: 88-91 JDM CRX/Civic SiR (EF-8/9), first gen b16. it has 20 splines and a smaller diameter shaft. cannot use 92+ clutch/pilot bearing. *optional LSD
3.166
2.052
1.416
1.103
0.870
3.000
4.266
YS1: 92-93 USDM B17A *NO LSD, JDM 92-93 XSi Integra *optional LSD. has 24 splines. any 92+ b-series clutch. 92-93 pilot bearing only.
3.307
2.105
1.458
1.107
0.880
3.000
4.400
Jdm b18c R LSD CRX si
TR "Old Skool EF" Member #96
JoKie TuNinG
RANGCRX BUILT TYPE R
StricKlyMT
727-510-6301
Old Oct 24, 2010 | 06:09 PM
HondaHouse's Avatar
IS AT THE DEALERSHIP NOW
so basically, if you can put a single cam clutch 89-2000 on the b series trans, you have a 89-91 trans....hydro b series clutches and 92-93 cable trans are the spline count.....
Mike @ 239-851-3234...anything pertaining to HONDAS
Originally Posted by Jordan T
sounds like you have a problem, your car is a mitsubishi, try replacing it.
Old Oct 24, 2010 | 09:47 PM
SUPAFLY's Avatar
gabe i got u on this i found out how to tell the diff. at the top of the case near the speedo the b16 has this lil hump thingy and ls doesnt lol figured it out lmao
TR "Old Skool EF" Member #152NO BOOST!!!!JUST MY FOOT AND THE BOTTLE!!!!!CRX SiR
88 crx dx-wrecked
91 crx si -project 300 whp allmotor-solddd
95 teggy-parting out
91 ex 4 door -sold
97 ek civic dx boosted-400whp
98 teggy gsr-dd
8137704076 b series parts for sale let me kno what you need
