Power Ideas needed for b18b1 swapped 94 eg coupe...
I had a ls swapped 94 coupe not too long ago. For mild gains do Intake, Header, Exhaust and hit up pherable.net and have your ECU chipped and tuned. with those mods I was able to beat a b16 swapped crx. you will be looking at around 160 hp at the crank.
If you have the extra money add in a intake manifold, adjustable cam gears, light weight pulley set and a earth ground kit (you can make 1 with 4 gauge speaker wire) and you will have a decent powered ls that will be very reliable.
WANK IT
^thanx for the good answer. Thats more what i was looking for.
I am going to do a comp test when i get home, and if it is in fact needy, i think i will just end up getting a swap for it. I really wanna do an h22 swap. I had a buddy that did one and that car was amazing.
nitrous is the way to go but you will still have to upgrade your injectors and fuel pump and put a cold air intake but if you want to have a little something...get a better ecu (chipped)
CTR PARTS & PERFORMANCE in Tampa and in New York
83 Rx-7 GS 11.80@1/4 (wrecked it)
83 Rx-7 GSL 10.50@ 1/4 (blew it up)
93 Eg Hatch w/nos 7.50@1/8 (ex wife took it)
94 Eg coupe 9.50@1/8 (re-poed cause of babymama)
99 ek sedan 11.32@1/8 (totaled it)
99 odyssey van (lowered on 19s)
^how much would you guys say a tune would be with all of the bolt ons? at a reputable shop that is. And im looking into the jdm h22 swap. I dont care much about balance, i wont be auto crossing or anything, i just want reliability and comfort and plenty of power on tap when i want it. And what all intake mainfolds can i use on my ls motor? Is there factory ones that work good or would i have to go aftermarket?
And ive never even heard of an earth ground kit, lol...
thanks again guys.
kyle...
thanks again guys.
kyle...
thanks again guys.
kyle...
thanks again guys.
kyle...
I'm pretty sure you can you use any b series intake manifold (ex: type-r), but for the price just pick up a skunk 2.
Hit up phearable.net they sell chipped ecu's and will also tune your car. I personally bought my b18b chipped ecu from them and was very pleased with the purchase.
A earth ground kit is basically fatter cables for the oem grounds. It's said you can gain power...i'm not sure about that, but it just stabilizes the electrical components
here's a pic. Notice the red arrow:
WANK IT
^really? i always thought the h series would provide more easy power.
and how does it work getting a flashed ecu?
do you just tell them what all you did or something and they burn you a chip?
you just tell them what mods you have and what you plan on adding and they'll will tune the ecu (increase air fuel ratio, up rev limiter, etc). They will actually solder the chip into your ecu that can be flashed with various engine management systems
WANK IT
A H22 swap isn't that much.
H2B and H2D swaps can be done for less than $4000.
200hp+, good tranny, new-ish motor, great potential (more than a b-series). Why not?
If you could keep AC with a H2D, I'd do it in a heartbeat.
OP just do the simple bolt ons I was telling you about and get your ecu chipped/tuned by phearable (they are local) and you will beat b16 swapped civics all day (I know b/c I used to all the time)
check out the comparison below:
right off the bat the LS motor has more tq and with simple bolt ons and a reflash you will have no problems hitting 170 hp at the crank
WANK IT
^i think i may go this route for now. i found a brand new skunk 2 intake manifold for 170 shipped, you guys think thats a good deal or what? I havent paid for it yet. Plus, how do you thihk it would repsond to boost later on should i decide to go that route?
