What mounts do I use for a B20 into a 99-00 SI?
Old Oct 14, 2010 | 05:44 PM
Dahondaman's Avatar
Default What mounts do I use for a B20 into a 99-00 SI?
Stocks B B16 mounts are in now but the back one doesnt line up. Is there a different motor mount I need to use? Thanks
Old Oct 15, 2010 | 06:23 AM
sullivanracing06's Avatar
idk how thats possible.... all b series use the same mounting pattern.... did you use the drivers mount from the b16 or b20? u need to retain all your factory mounts
Sullivan Racing LLC
352-665-2496-Tom
SullivanRacing06@aol.com
my lag is your courtesy head start
ATTENTION.... installing a head gasket, head studs or pistons and rods in your otherwise STOCK engine dose not make it a "built" engine! stop listing you cars for sale saying they are built when its not!!
Old Oct 15, 2010 | 09:34 AM
Dahondaman's Avatar
The driver side mount is a B16 for sure because i bought it myself. Just confirmed with the guy that sold me everything that the other mounts are B20 mounts. So do i need to change something here. Thank by the way.
Old Oct 15, 2010 | 11:00 AM
Thatguysstuff's Avatar
Hey its that guy!!
needs to be 99-00 Civic Si rear mount.. the t bracket right??
Old Oct 15, 2010 | 03:47 PM
EVERY MOUNT NEEDS TO BE 99-00 SI!
do not use any b20 mounting shit to install the motor, the piece that the drivers side mount bolts to that goes thru the t belt cover, u swap that out for the 99-00 si bracket? if not theres your problem..
and the t bracket needs to be 99-00si as well
Sullivan Racing LLC
352-665-2496-Tom
Old Oct 17, 2010 | 09:01 PM
Dahondaman's Avatar
Okay. Another question. Are the actual mounts interchangable with the brackets or no? i.e. can I just replace the brackets (i.e. T-bracket) and use the existing rubbers?
Old Oct 20, 2010 | 06:45 PM
Dahondaman's Avatar
Shoot didnt think it would be so hard to find someone selling a post mount.
Old Oct 21, 2010 | 05:58 AM
da92nv's Avatar
...let's blaze!
U need to remove the motor mount bracket from the engine and use the b16 mount. The B20 mount is slightly angled. Also like mentioned earlier, your t-bracket in the rear must be from a b16 also.
...TR's OldSkool DA Crew Member #00...
...TR's Oldskool DB Crew Member #02...
