mounting 310 injectors on ITR manifold
What would prevent a set of RC310 injectors from mounting flush with the fuel rail on an ITR manifold? It has like a 3mm gap.. do i need any extra fittings or just use a washer to do the trick?
This issue has been going on for a long time. Some people have problems, some don't.
I myself have never had a problem but perhaps I've just been lucky. Try putting a little oil around the grommets RC supplies, insert the injector into the rail, then install into the manifold, and tighten down. If that doesn't work you can always bust out a dremel and bore out your stock grommet and use that but I'd be careful going that route.
